PID Temperature Controller http://www-.luthiersforum.com/forum/viewtopic.php?f=10117&t=44896 |
Author: | Shane Neifer [ Mon Jan 12, 2015 11:47 am ] |
Post subject: | PID Temperature Controller |
I have been planning and collecting parts to make one of these for a few years. Last summer I bought more parts from the OLF classified (thanks Scott!) and just recently picked up the last few things I needed. I have looked through the posts and couldn't find what I was looking for so decided that as I struggle through this I would post on my successes and failures and hopefully at the end have a system that works. First off a couple of things: 1) I AM NOT AN ELECTRICIAN!!! I am documenting how I build this unit but you need to be comfortable in your process or seek advice. Electricity can be dangerous and can cause fires! 2) I am using two blankets so this unit may be more than most people want/need 3) Fred Tellier deserves consulting credit on the advice on some parts and wiring I have a couple of goals in my design. They are: 1) I want to know the temperature as the sides start to cool, that means when the relay to heat is shut off I still want a temperature reading 2) I may want to use other blankets or a different configuration so I am making this controller a stand alone unit with the blankets being able to be plugged in and out so I can change them. So, I started last evening when Rod True indicated that he was thinking about the same thing. We have recently moved and we are still unpacking so I don't access to my table saw, CNC machine, jointer, etc. Small hand tools will be all that I have. So, here goes! This is the bender I use, I may build a new one once I get the heating blankets all figured out. Attachment: Bender.jpeg To get started you need to collect your parts Attachment: Parts.jpeg Then you need to get something to place them into, for me it is 1/4" plexi glass because it was closest at hand. (for these parts and their mounting system I suggest going with 1/8" material as I had to make some modifications to get them installed into 1/4") Attachment: Plexi.jpeg Next, layout where you want the parts mounted Attachment: Layout.jpeg Then cut out for the components (this took a couple of hours or more with drill press, coping saw and files) Attachment: Cutout.jpeg And then install the components into the faceplate Attachment: installed.jpeg When I bought a but of the pieces as a lot it came with switches that light up and require a separate power 12V supply, so again this may be more than is required but "non-powered" switches are readily available and would simplify the project. Anyway, I will start wiring today and will explain what is going on as that progresses. Thanks Shane |
Author: | James Orr [ Mon Jan 12, 2015 12:50 pm ] |
Post subject: | Re: PID Temperature Controller |
Shane, thanks for the thread and taking the time. Do you mind detailing what the parts are? |
Author: | Rod True [ Tue Jan 13, 2015 10:23 am ] |
Looking good Shane. Nice set up there Fred and Ed. I'll post pictures of mine when I've got it done. Just waiting on components. |
Author: | Allen Ughoc [ Sat Feb 21, 2015 4:14 am ] |
Good stuff gentlemen. I'd like to upgrade my old LMI controller, electricity is not my strongpoint... |
